leak
Old Jun 30, 2012 | 10:24 AM
Dtrain36's Avatar
7th Gear
Default leak
Hi all!
I just came back from a two week vacation and when I pulled the car our the parking spot, I noticed a big patch of what looked like watery oil directly underneath the car. I checked the oil levels and it was normal, and there were no faults or anything when I started up and drove for a bit. Any idea what it could be? I have a 2006 LR3 with 64,000 miles.
Thanks
Old Jul 1, 2012 | 04:03 PM
Dtrain36's Avatar
7th Gear
Well, I took the truck into the place here I get my oil changed, and they said that my front differential gasket is leaking. Any idea how much this is going to cost me?
Old Jul 5, 2012 | 11:05 PM
oilspotLR's Avatar
Could it be a O ring on the diff fill/drain plug or is it the cover on the back side??
Probably wouldn't be a hard job to do yourself. Pull drive shaft and take bolts off. Might need a impact wrench and breaker bar! Oh yeah and biggest requirement, if you don't have a lift, I hope your small and skinny because your going to be under the truck for a while!
Old Jul 6, 2012 | 09:57 PM
unseenone's Avatar
There is a replacement front breather cap. The original one allowed pressure build up, and blown seals. You might also consider rebuilding the diff and replacement the bearings as well seeing as you will have to have it halfway apart anyway. You will need to cut the old breather cap off at a 45 degree angle, and slip the new one on. I used a cable tie to secure it.
Here is a thread describing the issue / operation
Here is the LR TSB on the breather
Here is my gallery;
Old Jul 15, 2012 | 04:46 PM
killerpav's Avatar
Where can you get this part? My rover doesn't have this done yet and I can't find the part.
ZMonet
Jun 24, 2016 04:00 PM
tito5590805
Sep 27, 2010 11:32 AM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
rgrizzard
Mar 6, 2008 10:16 AM
