Leaking Power Steering Fluid..help!!
Old May 28, 2019 | 07:32 PM
Athana's Avatar
Default Leaking Power Steering Fluid..help!!
Hi..
About 14 months ago mechanic said Power Steering Hose looked like it needed replacement..it must have been 10 years old or so.He did it.
Two months ago Steering Fluid Leaking..took it in to another mechanic as other guy closed Shop and they changed O Rings that join Rack to Hose as previous were cut up for some reason.
Last week Fluid Leaking again..say Hose kinked near Rack leaking there and O Ring destroyed again ??
Let's get a new Hose ..we sit around for 6 hrs..They put in the new oem hose and O Ring (s)..on the way home Steering Wheel feeling tight and pebbley and not accurate...??? Maybe air in the line he says..
And now I think I see Fluid Leaking again ?
Please help..it is our only car.
Thank you for your help.
Old May 28, 2019 | 10:30 PM
Athana's Avatar
Default Please what can it be..what's the next step?
Old May 28, 2019 | 11:05 PM
DakotaTravler's Avatar
Next step is to take it back the shop that fixed it. I mean if you are paying them to fix something, it should be fixed correctly.
Old May 29, 2019 | 07:30 AM
Athana's Avatar
But what is problem likely to be?
They said if that didn't solve it the Steering Rack may need to be replaced..a $750 part : (
Old May 29, 2019 | 09:25 AM
Without seeing it, its hard to say. That is what the shop is for. There is no reason to replace the rack if they say the lines is what is leaking.
Old May 29, 2019 | 01:33 PM
Athana's Avatar
It seems to be leaking where the hose attaches to Rack..
Old May 29, 2019 | 07:56 PM
The seat where the hose goes in could be burred and that is what is cutting the o-rings.
Old May 30, 2019 | 08:05 AM
Athana's Avatar
Thanks how to solve this?..is seat replaceable or needs to be filed.?? Many many thanks.
Old May 30, 2019 | 09:42 AM
AtlantaViking's Avatar
Without first hand feedback, you are asking for something that is almost impossible to provide. Since you have a shop between you and the issue, a lot can be lost in translation.
I think you'll get more educated responses if you have the shop provide photo(s) of the problem areas to you and then perhaps you could put them up here so others can put your descriptions to the actual images.
Old May 30, 2019 | 10:33 AM
Athana's Avatar
Burred Seat ..what is solution..replacing whole rack?
