Leaky VCT Oil Solenoid
Old Apr 8, 2019 | 07:24 PM
junya's Avatar
Came across this old thread, just want to note there is no need to remove the covers. Just use a flathead and pry up gently on the seal. It will slide right up and over the sensor. Lubricate the new one slightly and slip it on. I just did both and it took me less than a minute.
^^^This. Absolutely no need to pull the valve covers to replace the seal.
Old Apr 9, 2019 | 10:48 AM
No kidding that is awesome. I had been putting this off since I didn’t feel like bothering with pulling the covers good info
Old Apr 11, 2019 | 04:02 PM
abran's Avatar
land rover only sells them as a [art of the valve cover kit, but jaguar sells just the VVT seals.
Old Apr 11, 2019 | 05:18 PM
Nosugar0carbs's Avatar
Just for you guys, Ford sells them too.
Old Apr 11, 2019 | 08:01 PM
thorgal's Avatar
Tired of spending 40+ bucks on Jaguar seal. Mine started leaking after just two years. Ordered a few on Amazon for 8. 40 each. It has been almost two years now and no leaks so far.
Price I can live with...
Old Apr 14, 2019 | 04:37 AM
houm_wa's Avatar
Default My Tech tells me...
...there is no real need to replace them just for some oil seepage but hell if it's really that easy then why not?
Old Apr 14, 2019 | 06:33 AM
Sure, but a deep turns to a weep, then a weep drips on your alternator and burns it out.
Old Apr 14, 2019 | 01:20 PM
DakotaTravler's Avatar
Mine were not leaking, I replaced as a preventative measure. In fact I had the seals for almost a year before finally doing them. But my thoughts are that if oil can get out then maybe other things can get in, including unmetered air. And the 4.4 is so dang sensitive to any sorta air or exhaust leak.
Old May 7, 2019 | 05:54 PM
houm_wa's Avatar
@DakotaTravler any tips?
I have the Jag-part O-rings. I have a chiseled-edge putty knife, and I'm ready to go. Was there anything that complicated this job? Did the solenoid pop out with ease? Any tricks to orienting either the O-ring or the solenoid? Passenger side looks a bit more of a pain but still easy to get to. Did oil spurt out? Any tools that made the job easier that you didn't think you'd need? Anything you can tell me is greatly appreciated.
Old May 7, 2019 | 05:57 PM
Its really easy. Even a smaller flathead will do just fine. Disconnect the solenoid. Then simply lever upwards under the edge. Work at a couple spots, like noon and three, for example. It will slide right over. Solenoid stays in place. No oil comes out, but be sure to clean things before installing the new one. It really is a 30 second job once you have done one.
