LED grill light bar install
Old Sep 8, 2017 | 05:14 PM
cmb6s's Avatar
Originally Posted by djkronik57
How is the aux battery vented? I know you can run into corrosion issues with the main battery if the vent tube is disconnected or clogged and all the electronics in the area.
Pretty sure that's a sealed AGM battery that doesn't need venting.
Old Sep 9, 2017 | 07:40 AM
Rufflyer's Avatar
Default Venting aux battery
I ran a standard lead acid battery in the left side. I got the plastic fittings that fit in the side, and a rubber hose from the auto parts stste and ran the hose out the front of the box, then down past the plastic splash shield. Never had a problem for the 3 years it was in.
Jeff
Old Sep 19, 2017 | 07:21 PM
Colb.45's Avatar
4wd High
Love the grill LED light bar! that is a wicked addition.. doesnt help fuel my addiction for lighting
Old Sep 20, 2017 | 10:33 AM
abran's Avatar
My install got sidetracked by a customers car. Hoping to finish his light bar install with mesh grill today. I will post pics
Old Sep 20, 2017 | 11:36 PM
abran's Avatar
Soooo, my big plans to use an aftermarket mesh grill didn't quite work out. I did a bumper/winch/light bar install for a customer.
the vent sections on the aftermarket grill are longer than OEM so it's not as slick. Check the pics. Also this is the first TP4X4 bumper installed in the US!
Old Sep 21, 2017 | 08:19 AM
I've been eyeballing that same grill myself. Was it plug and play? How close is the gray to bonatti?
Old Sep 21, 2017 | 09:01 AM
abran's Avatar
It's plug and play. I put it on my friends Bonnati grey 3 and it matched. I'm tempted to say perfectly but some people are more picky than others.
Old Sep 21, 2017 | 09:06 AM
EastCoast's Avatar
Not a fan of the sheet metal screws showing on the front of the bumper... just a picky person's opinion....lol
Old Sep 21, 2017 | 09:22 AM
abran's Avatar
Like I said... I actually like the stock bumper with hidden winch mount.
Old Sep 22, 2017 | 07:57 AM
Damn it I was hoping you would say it was a horrible color match lol....
