Left Blinker / Indicator Issue Inside LR3
Old Feb 29, 2020 | 12:53 PM
nevillusa's Avatar
Default Left Blinker / Indicator Issue Inside LR3
Hi. Strange issue. 2008 north american LR3 HSE. The green light on the dash, along with the sound inside the car, is 'too fast', when I turn on the left indicator/ blinker. Same symptom as when a Bulb has blown.
However, the 3 places on the outside of the vehicle (front left corner, rear left corner, and front side) are all operating correctly - all bulbs are working, and the flashing sequence is normal (not too fast).
Perhaps I have a bulb that is 'almost' or 'slightly' broken? Throwing an incorrect electrical signal?
Old Feb 29, 2020 | 02:35 PM
houm_wa's Avatar
Default Is there a relay for the blinkers?
If so...that's worth a check
Old Feb 29, 2020 | 02:45 PM
DakotaTravler's Avatar
FYI, in the event of a bad bulb it will not blink faster outside but it will do as you say on the cluster. I had a rear blink go out and it did just that. So that is normal operation for a bad lamp. I would probably just replace the lamps and see what happens. I tend to replace all exterior lamps once a year anyway as maintenance.
Old Mar 1, 2020 | 12:29 PM
nevillusa's Avatar
Reporting back - FIXED
  • Swapped out both Bulbs. (Front and rear driver side).
  • It was actually the Rear Bulb that caused the issue. Perhaps because 'wrong' Bulb was in there? (Bulb that I removed had 2 electrical contact points at base of Bulb, part # 7528. New Bulb had just 1 electrical contact point).
  • Both removed Bulbs were very 'discolored' (inside glass and inside bits were quite 'brown'). This may be normal I suppose.
  • Didn't research the best Bulbs to buy; wanted to get this done quickly, so I just picked up Sylvania brand from local auto-parts store. Used their cross-ref book to determine what to purchase.
  • New Rear Bulb - Sylvania 7506
  • New Front Bulb - Sylvania 3457
  • Used rubber gloves when handling the new bulbs.
  • Used NO-OX-ID A-Special Electrical contact grease on the electrical contact areas.
  • Used Dialectic Grease around the electrical connector housings.
Couple of images, showing old Bulbs beside new Bulbs -
Front - LR3 Front Indicator Bulb
Rear - LR3 Rear Indicator Bulb
Sidenote - When it gets a bit warmer I may replace all of the interior bulbs to LED, with a whiter color. Front Fog Lights are also quite 'yellow' - May look into swapping these for whiter bulbs.
Cheers, Simon
Old Mar 1, 2020 | 09:40 PM
I did an LED swap on the interior. I went with these (link below) but dont care for them, they are very cool in color temp and they are also rather dim. So I am going to try another set.
Amazon Amazon
As for fog lights. I need to replace one of mine because of a cracked lens. But I have lamps on standby and I went with traditional yellow. When it comes to fog lights for fog use, warmer color is better. For looks though, I agree that a nice HID look can be attractive. Just not my thing.
Amazon Amazon
Old Mar 2, 2020 | 01:15 AM
houm_wa's Avatar
I was thinking the same thing...for fog light color. There is conflicting data about it, but I've seen some reports asserting that there is a relationship between color-temperature and retro-reflection in fog. Those reports support what we are saying.
Old Mar 2, 2020 | 09:47 AM
nevillusa's Avatar
Thanks. I'll leave the front Fog Lights alone.
TOM R
Dec 12, 2023 08:31 AM
Derek Gjessing
Jul 7, 2018 02:03 PM
djdart
Nov 14, 2015 01:03 PM
jimmyc
Dec 9, 2013 01:22 PM
bballjames
Nov 27, 2012 11:46 PM
