lose of gas pedal engine stall
Old Nov 21, 2014 | 09:55 AM
TOM R's Avatar
Default lose of gas pedal engine stall
well past 2 days we have been intermittently losing the gas pedal and the engine shuts off, always restarts just dangerous, waiting on the mechanic, ideas?
Old Nov 21, 2014 | 10:32 AM
unseenone's Avatar
Perhaps a badly fouled throttle body.
Old Nov 21, 2014 | 09:07 PM
thorgal's Avatar
Could be a faulty throttle body sensor.
Old Nov 22, 2014 | 09:39 AM
TOM R's Avatar
cleaned throttle body and maf, made sure all was tight no corrosion in connectors, oil fill cap and tube tight and still losses throttle, stalls when coming to a stop
this is no longer intermittent, everytime you slow to stop or turn the engine stalls
I did not remove what I assume is the iacv cause it looks like there are coolant pipes going into a plate under it ?
thoughts?
Old Nov 22, 2014 | 02:57 PM
TOM R's Avatar
well after a bunch of pain in the *** stuff today I finialy realized it is out of gas at 1/4 tank guess need a sender
spoke to the mechanic he said there are 2 senders, the front goes bad and they are so hard to replace even with tank out that under warranty they used to swap the entire tank as a unit for a bad sender, wow
Old Nov 22, 2014 | 06:34 PM
thorgal's Avatar
thoughts?
Sometimes it is a sensor in throttle body , that gets cooked and one has to replace the whole unit as the sensor cannot be purchased separately . That is what actually happened to me few years back and yes there are coolant pipes going into a plate as well to answer your Q. Tom. cheers
Old Nov 23, 2014 | 08:07 AM
TOM R's Avatar
Psst I was out of gas, bad sender
Thanks anyway
br0keit
Aug 31, 2012 08:13 AM
SWAINROVER
Nov 6, 2011 10:10 PM
Double J
Dec 27, 2009 03:32 PM
stokiemike
Dec 17, 2007 11:26 AM
eriqcharlz
Jul 3, 2007 09:30 AM
