LR3 2005 105,000 HDC not available
For no apparent reason happened 2time cleared faults reset was good for 3 day’s driving slow straightaway
lcd HCC unavailable
suspension drops to access height and dead there.
codes
U046-86
B1B02-28 low frequency coil
c1A00-88
U0122-87
U0416-94
U0416-86
any ideas or direction to move in will be appreciated guys!
I found the right side rear small safety bulb blown just now could that be causing my problem ?? ?
lcd HCC unavailable
codes
U046-86
c1A00-88
U0122-87
U0416-94
U0416-86
lcd HCC unavailable
codes
U046-86
c1A00-88
U0122-87
U0416-94
U0416-86
lcd HCC unavailable
codes
U046-86
c1A00-88
U0122-87
U0416-94
U0416-86
And new to using it.
I cleared all the faults so I believe I’ll have to wait to see if this problem crops up again
today is when I found the trk dead got a jump and found a really loose negative connection? Retightened both and it’s been ok right now also found a blown side marker bulb and replaced it time will tell.
thanks for your reply
Bad battery voltage, grounding issues, and even burnt brake light bulbs cause all sorts of mayhem with the LR3. They most commonly throw Uxxxx and Bxxxx codes due to those problems, which is mostly what you had. Hopefully by fixing those issues you will have cleared up your problems.
ok Thankyou time will tell .
The following 2 users liked this post by Viking1:
douglastic (12-05-2022),
P-Bod (12-04-2022)
