LR3 2005 105,000 HDC not available
Old Nov 25, 2022 | 03:39 PM
Viking1's Avatar
Default LR3 2005 105,000 HDC not available
For no apparent reason happened 2time cleared faults reset was good for 3 day’s driving slow straightaway
lcd HCC unavailable
suspension drops to access height and dead there.
codes
U046-86
B1B02-28 low frequency coil
c1A00-88
U0122-87
U0416-94
U0416-86
any ideas or direction to move in will be appreciated guys!
I found the right side rear small safety bulb blown just now could that be causing my problem ?? ?
Old Nov 27, 2022 | 11:40 AM
NJOverland's Avatar
lcd HCC unavailable
codes
U046-86
c1A00-88
U0122-87
U0416-94
U0416-86
If you can get a gap tool and post a log you'll get more responses. Most of us can you tell with somewhat certainty what the issue is if you do that.
Old Nov 27, 2022 | 11:45 AM
DakotaTravler's Avatar
Or at least post what the codes me... I am not looking those up.
Old Nov 27, 2022 | 03:07 PM
Viking1's Avatar
ok Im using an iCarsoft LR V2.0 for Jags and LRs diagnostic tool.
And new to using it.
I cleared all the faults so I believe I’ll have to wait to see if this problem crops up again
today is when I found the trk dead got a jump and found a really loose negative connection? Retightened both and it’s been ok right now also found a blown side marker bulb and replaced it time will tell.
thanks for your reply
Old Nov 28, 2022 | 07:03 AM
SeattleDriver's Avatar
Bad battery voltage, grounding issues, and even burnt brake light bulbs cause all sorts of mayhem with the LR3. They most commonly throw Uxxxx and Bxxxx codes due to those problems, which is mostly what you had. Hopefully by fixing those issues you will have cleared up your problems.
Old Nov 28, 2022 | 03:28 PM
Viking1's Avatar
ok Thankyou time will tell .
Old Dec 3, 2022 | 07:03 PM
Viking1's Avatar
Default HDC not available update
She’s still purring like a Lion no faults!!!
Sdover
Nov 27, 2020 08:41 AM
mx468
Oct 5, 2017 03:40 PM
ljdiscovery
May 9, 2017 07:17 PM
chris_craft
Jul 30, 2008 09:07 PM
Kooner
Sep 26, 2007 05:11 AM
