LR3 Air Compressor Conversion??
Old Feb 14, 2017 | 10:41 AM
outdoor junky's Avatar
Default LR3 Air Compressor Conversion??
I am doing the Air to Coil Conversion on my LR3 and was wondering if anyone has
converted there air compressor into a functioning source of air for tires or anything else.
I want to install a toggle switch setup for the compressor power and run off the original air tank.
I haven't found anything yet on here so figured Id ask.
Thanks
Old Feb 14, 2017 | 01:26 PM
cmb6s's Avatar
The question has been asked before and the general consensus was that the EAS compressor is really a high pressure, low volume compressor with a relatively low duty cycle. Air compressors for inflating tires are high volume, low pressure, high duty cycle compressors. So... can you? Yes. Would it work well? Probably not... Even if you used the EAS reservoir, I think it would be a very slow process to inflate all 4 tires with the EAS compressor.
I'm sure others here would be very interested to learn the outcome if you did it though.
Old Feb 15, 2017 | 01:05 PM
houm_wa's Avatar
It does seem like a good re-purposing though. I'm assuming you aren't really an off-roader so your new use for the compressor would be less to air-up after a trail run but maybe to inflate a flat in the one-off circumstance of having a low/flat tire. To me that would be worthwhile.
I have a separate air compressor mounted in the rear. Super convenient.
ljdiscovery
May 28, 2014 09:46 PM
95RoverLWB
May 4, 2012 02:39 PM
aircraftguy
May 17, 2009 07:38 PM
LandRoverDiscoDos
Apr 7, 2007 04:49 PM
KWLR3
Jun 24, 2006 06:10 PM
