LR3 Air Suspension issue - won’t raise
Old Aug 1, 2018 | 04:19 PM
gpompa's Avatar
5th Gear
Default update: GAP tool arrived and scanned for faults
Originally Posted by houm_wa
I suppose when you get your GAP tool you can take off those rods and check the calibration and all that...
GAP diagnostic tool arrives, got it setup and pulled this fault code:
- C1A30-64 (AF): Both switches pressed at the same time - Algorithm based on failure - signal plausibility failure
Since the last post and before GAP tool arrived, I re-installed stock rods on the height sensors and vehicle has been holding air. However, front driver side is lowest than rest of vehicle. Red suspension light will come and give "max 30 mph" message then turns amber if speed is reduced to 25-30 mph or less.
Any ideas on what to check now?
Old Aug 1, 2018 | 04:59 PM
Michael McGee's Avatar
Default Need a reliable SUV
Hi,
I am currently a Toyota Tacoma owner ,but now have a family. I need something reliable and 4 wheel drive with more room. I love the LR3 ,but have never owned one and everyone I ask says that they are money pits and break down all the time. I have found the 2008 LR3 with high miles but I dont want to keeping something that is in the shop all the time. Please help guys. Thanks. Name is MIke FYI.
Old Aug 1, 2018 | 05:24 PM
houm_wa's Avatar
Mike, it's high maintenance but awesome....if you are going to take it off-road and love it. If not, go for a 4Runner.
@gpompa I'd check the calibration and consider re-calibrating it. Sounds like it could be a cross-articulation issue.
Old Aug 1, 2018 | 06:03 PM
gpompa74's Avatar
I swapped a 60a fuse (it tested ok) and cycled engine on/off.
Now, only getting the following suspension-related fault code:
Suspension
  • C1A00-1D (AF) Control module - General electrical failure - circuit current out of range
    ( on 01-08-2018 17:50:33 at 238698 km )
Still proceed with calibration?
Old Aug 1, 2018 | 07:18 PM
houm_wa's Avatar
Well....CHECK the calibration first. See if it's within spec and/or if it's reasonable. Then if necessary proceed. With the fault you are seeing now, what are the symptoms? Same? Usually the red fault with a tie-in to speed, it's a calibration issue or a bad sensor.
Old Aug 1, 2018 | 09:49 PM
gpompa74's Avatar
Thanks again for the reply.
Same symptoms: front left dipped and opposite is much higher, cannot use have height switch to switch modes.
I used GAPtool Service Test function to check the air valve blocks. This allowed to get the front to raise and level out. The rear leveled as well BUT will not raise. So, it seems I may need to check the electrical connection to rear valve block (changed o-rings 2 weeks ago), or replace it.
Then, once I restore rear valve block I should be able to re-calibrate and all should be fine.
Am I on the right track? Anything else to keep an eye on?
Old Aug 2, 2018 | 08:18 AM
Sounds like you are tracking pretty well.
Old Aug 2, 2018 | 03:31 PM
houm_wa's Avatar
Have you checked the calibration numbers against the allowed range of the sensors?
Old Aug 2, 2018 | 04:13 PM
gpompa74's Avatar
The culprit was the rear air block valve electrical connection wiggled itself loose and why the GAPtool couldn’t raise the rear of LR3. I snapped it back into place and Rover is happy. The right diagnostic tool, this forum, & online manuals are a life saver.
Easy and no cost to fix except GAP tool expense (or investment) which will save me thousands down the road !!!!
Old Aug 2, 2018 | 05:25 PM
True story
