LR3 Compression
Old Jun 1, 2016 | 09:06 AM
Hanomag's Avatar
Default LR3 Compression
What is considered servicable compression for a 2006 LR3 4.4 engine. The Jag engine? I am in need of a used engine and found one that was 125 dry and 150 wet with very little variance between the cylinders. Thoughts?
Old Jun 3, 2016 | 10:16 PM
jafir's Avatar
That seems really low, but it could be carbon on the valves, or the fact that the drive by wire throttle is closed. If it's pretty even I'd probably chance running it, but I'll bet 125 is too low for the spec.
The engine that was toast in my LR3 had better compression, at least on the cylinders that had it. Most were in the 160s, one was 175 and one was 110 and one was 0.
nh9095
Jan 14, 2019 12:36 AM
Tim Meal
Jan 10, 2008 12:05 AM
afphinfan
Jan 1, 2008 05:58 PM
dlkk
Sep 21, 2006 09:09 PM
orl1jvc
Mar 16, 2005 10:44 PM
