LR3 Current Software???
Old Feb 15, 2013 | 12:06 PM
mx468's Avatar
Default LR3 Current Software???
How can you tell if you are running the latest software in your truck module thats suppose to fix the stop go hesitation in your lr3 that some people are mentioning about in these forums?
Old Feb 16, 2013 | 12:56 PM
Rovin4life's Avatar
Its not the latest software causing issues, its the mismatch of programs. For example having a transmission ecu with an earlier update compared to the pcm. You are supposed to have them programmed together or else it leads to the hesitation.
Old Feb 19, 2013 | 09:02 PM
LR Techniker's Avatar
The only way I know, is to hook up the SDD unit and select "configure existing module". It will compare what is installed with what is available. It will tell you if you have the current software, or if there is something new out.
Its not something that can be done by a DIY or something done via email. Vehicle must be in the shop.
lipadj46
Sep 14, 2010 01:17 AM
karlc
May 31, 2010 06:13 PM
karlc
May 21, 2010 08:18 PM
Danny Lee 97 Disco
Apr 2, 2010 10:37 AM
luxury1
Feb 6, 2009 01:14 PM
