LR3 Fuel Guage out
Old Jul 2, 2013 | 10:31 AM
hattoe's Avatar
4wd High
Default LR3 Fuel Guage out
Yesterday my 2005 LR3 (101,000 miles) fuel gauge appears to have gone out. I put 10 gallons of gas but gauge reads Empty and the low fuel light stays on all the time.
I have been told to change the fuel pump inside the tank because the sender is bad. Approximate cost of a new one is about $800. EESH.
Any thoughts??
Old Jul 2, 2013 | 11:41 AM
er1c's Avatar
I've read about guys replacing just the fuel tank sending unit on their LR3s. I've never read about them having to replace the fuel pump. I know some vehicles it's integrated into the pump. But, I don't believe that's the case with the LR3?
Old Jul 2, 2013 | 12:19 PM
hattoe's Avatar
4wd High
You are right er1c. Comes down to changing the rear sender. If that does not work then you have to change the front sender, which, unfortunately, can only be changed by swapping out the entire gas tank!!
hilltoppersx
Oct 4, 2010 05:44 PM
rykrover
Mar 1, 2010 06:24 PM
dombam
Oct 28, 2008 08:22 AM
Prepilot_3ck
Jul 20, 2006 06:46 PM
hollyw
Jan 28, 2005 09:50 PM
