LR3 fuel pressure regulator
Old Jan 18, 2016 | 04:11 PM
dmbenson's Avatar
Default LR3 fuel pressure regulator
Where is the 20017 LR3 fuel pressure regulator located and is it vacuum operated? I looked along the fuel rails and did not locate the FPR.
Old Jan 27, 2016 | 10:59 PM
Volkov's Avatar
From the technical introduction manual
"FUEL PUMP- the submersible electric fuel pump is attached to a carrier and is located at the bottom of the swirl pot inside the fuel tank. The fuel pressure regulator, which controls the fuel pressure in the feed pipe to fuel rail, is located in the fuel manifold in the fuel tank.
FUEL PRESSURE ACCUMULATOR- A fuel pressure accumulator is attached centrally to each of the fuel rails. The accumulators act to dampen pulses from the pump and ensure that the fuel pressure in the rails is constant"
herblatham
Apr 12, 2013 11:13 AM
Akumal
Nov 6, 2012 03:04 PM
robertnsmith
May 3, 2011 11:52 AM
leadfoot
Sep 13, 2009 09:51 AM
mac25dm
Sep 6, 2007 10:23 AM
