LR3 grinding sound. Please HELP!
Old Jan 2, 2015 | 11:52 AM
kukusya's Avatar
Default LR3 grinding sound. Please HELP!
I start have a grinding nose under car and little kicks in pedals (feel like ABS) when I turn LOW mode transfer case on and start driving it. And on control panel display axle pictures .
Thank you
Old Jan 2, 2015 | 04:49 PM
TOM R's Avatar
Low suspension or low range in transfer case?
Old Jan 2, 2015 | 08:33 PM
kukusya's Avatar
Low range transfer case. It was if service 23k miles ago. I heard some noise but this one sound more violent.
Old Jan 2, 2015 | 08:58 PM
TOM R's Avatar
Think I would have it checked, where are you driving in low range?
Old Jan 3, 2015 | 08:21 AM
thorgal's Avatar
hill descend control makes grinding noises as it uses ABS for braking.
Old Jan 3, 2015 | 09:10 AM
TOM R's Avatar
Good point, you can always post a video of the noise, that way we can try to tell what it is
Old Jan 3, 2015 | 11:03 AM
kukusya's Avatar
Thank you. Good point next time I will film.
Old Jan 4, 2015 | 09:10 PM
houm_wa's Avatar
Could also be the rear diff. I just went through this. Do you have the locker?
Old Jan 4, 2015 | 09:50 PM
kukusya's Avatar
Yes I do have it. But noise only coming when low range engage.
Old Jan 5, 2015 | 02:19 PM
houm_wa's Avatar
Correct. I JUST had this (like I mean it was fixed last week). It was a clanking noise as if something was binding and then releasing. Felt and sounded like it was from right under my a$$....middle/rear of the vehicle. I thought it was a U-Joint or CV-Joint...maybe a bad prop shaft or stub axle. None of the above; it was my (locking) rear diff, which was all of about 20,000 miles old! I'd changed the oil twice in that span, too....for good measure.
It was in 4-Lo only, especially Rock Crawl, and it occurred even more reliably with increased torque like a hill climb and with some steering wheel input.
Dlk0099
Jul 8, 2021 05:37 PM
Alby Blkmth
Mar 26, 2013 11:25 AM
adambarry
Mar 30, 2010 08:17 AM
christians1600
Dec 17, 2009 09:47 AM
trangle23
Nov 20, 2006 12:39 PM
