View Poll Results: What fixed your Heater blowing hot on the drivers side issue
Replaced Heater Core
10.00%
Was able to flush Heater Core, Still a Heater Core issue
30.00%
Replace Air Blender Door Motor
0%
Never had this issue. If you never had issue, please post mileage!
60.00%
Voters: 10. You may not vote on this poll
LR3 Heater Distribution Issue
Old 12-23-2016, 02:43 PM
cybercop's Avatar
Default LR3 Heater Distribution Issue
It seems that a lot of folks have had the issue where no or little heat is observed blowing from the drivers side vent, but is good on the passenger's side.
The supposed fixes range from replacing the Heater Core to Replacing the air blender door actuators.
So, I figured I would take a poll and see who had which issue.
Old 12-23-2016, 04:01 PM
abran's Avatar
216,000 and 168,000, no heat issues.
Old 12-23-2016, 07:13 PM
Coleroad's Avatar
07 with 115,000 miles. I've changed the coolant every two years though.
Old 12-26-2016, 02:11 PM
cybercop's Avatar
That seems to be the key. I just bought one with 90k on it and it seems to have this problem. Will be digging into it this week.
Old 12-28-2016, 03:35 PM
DavC's Avatar
115000 miles
Never had issue. I did after purchase do the blend motor doors adjustment procedure. It's on the forums somewhere, press a few buttons etc.
Old 01-01-2017, 02:03 PM
DMMDTM's Avatar
In 2015, new to me '06 had limited heat to drivers side. Local rover specialist said to try a flush first before diving into the whole heater core replacement mess. I'd call it about 90% cured.
Old 01-02-2017, 06:32 PM
LR Techniker's Avatar
I have flushed multiple heater cores for that issue, replaced ZERO door actuators.
Old 01-02-2017, 07:33 PM
EastCoast's Avatar
Had mine done and it seemed to be fixed but one day later it was the same? Should I flush it again? Tech said that not much sediment came out. Does it need to be done with a machine or is shop air pushing water good enough?
Old 01-02-2017, 07:42 PM
Machines are usually good for "coolant exchange". I've never seen one that actually knocked stuff loose and "cleaned" a cooling system. Really dirty systems usually require chemicals that you wouldn't want to put in a coolant machine.
When they did the flush, did they flush the core in both directions? I use water and air and I keep alternating directions. Backflushing gets the most debris, but I sometimes get some forward flushing as well, not to mention the change in flow direction helps dislodge debris.
Repeat cases may require rinsing out the block and possibly replacing the radiator. If the heater core keeps plugging up, then sediment has collected elsewhere in the system and is being re-distributed back to the core.
EastCoast (01-03-2017)
Old 01-03-2017, 11:48 AM
houm_wa's Avatar
124,000 Miles
Quick Reply: LR3 Heater Distribution Issue
