LR3 ignition on source / front cig lighter power
Old Mar 30, 2019 | 04:47 PM
DakotaTravler's Avatar
Default LR3 ignition on source / front cig lighter power
A couple of questions I could not find answers to in a search. Any help is appreciated.
I have the LR3 wiring schematics, but I am not clear on a couple things. Probably cause these diagrams give me headaches. I am finishing up a Blue Sea auxiliary battery install. I have a cable loom of 12 wires ran into the cabin and I want to use as few of those as possible, they are intended for controlling relays with lighting and accessories. The Blue Sea relay has a remote switch which will use two of these 12 wires for the switch. A third wire from the relay is a simple ground which will stay the engine bay. A fourth wire needs to go to an ignition on source. Is there such a course available in the engine bay? Schematics keep pointing me to the engine bay. This is pretty much just a voltage sense wire, so there is no significant amp draw.
Second part. When I install my switch panel I will be without the factory cigar lighter. No prob because I will use its ground as a ground for my switches. But the positive power I would like to wire back to the aux battery for the Blue Sea switch. It has LEDs indicators and should really get power from the aux battery, not the main. From what I can tell this may not be possible because the cig goes to the JCB which is more of a brain box relay and it does not have a dedicated wire going up into the battery compartment fuse box (and thus no fuse there). In this case, I may have to bite the bullet and just use another wire for 12v+ from the aux battery (fused of course).
Old Mar 30, 2019 | 05:12 PM
Rufflyer's Avatar
Both of the lighters are switched. The connectors have a + and a -. They are in a t type connector. The connector on the right has another single connector I think that is blue next to it that is switched with the dash illumination not the ignition.
Hope that helps
Jeff
Old Mar 31, 2019 | 12:03 PM
jagmandan's Avatar
For switched 12V in the engine bay, I used an "add a circuit" fuse tap at the fuse box. Don't quote me on this, but I think it was open one for rear seat heaters or something that my truck doesn't have.
Old Mar 31, 2019 | 12:10 PM
I figured it out. I did not read the install correctly. Actually I did not read it at all, I was reading eh wiring schematics. I don't need a accessory-on source, I just need a momentary 12v+ source that will activate the 3-5 minute disconnect. To add, this is even optional. What is does is disconnect both battery banks during starting and delays reconnecting for a short time. Its not required in a setup like this, but I am going to do it so the starting battery gets a little lead time on charging. So the source needed can actually be the the 12v+ starter engagement wire from the ignition switch. Should be a brown wire with red stripe. That will be pretty easy to locate in the engine bay and tap into that.
So that's fine.
For the aux battery 12v+ source... still not sure as I may just end up using one of the 12 wires. Everything seems to run through the JCB. I never realized how critical that box is to the operation of the vehicle. I see why a water leak onto it can really mess up an LR3.
LR03NJ
Jan 14, 2017 12:41 PM
Jean Filion
Feb 8, 2015 09:57 AM
vette427sbc
Feb 19, 2014 03:38 PM
ebg18t
Dec 18, 2011 05:06 PM
LR03NJ
Audio/Visual Electronics
May 6, 2010 04:40 AM
