Tap Power from Ignition
Old Jan 13, 2017 | 11:09 PM
LR03NJ's Avatar
Default Tap Power from Ignition
Is there a wire in the engine bay fuse box that I can use only when ignition switch is on? Can anybody point me to that wire, if possible? thank you
Gerry
Old Jan 13, 2017 | 11:19 PM
mln01's Avatar
What are you trying to power?
Old Jan 13, 2017 | 11:25 PM
abran's Avatar
Contact Paul.
he has OEM conne tirs for the blank spots in your fuse box.
lr_connectors@btinternet.com
Old Jan 14, 2017 | 11:05 AM
OffroadFrance's Avatar
Gerry
Gerry, there are many 12v ignition controlled and fused supply tappings in the engine bay but it depends on what you want to power, you need to state/know the voltage and amps to be consumed.
Try Abran's guy Paul but he'll ask you the same/similar questions no doubt so have the answers ready eh
Old Jan 14, 2017 | 11:44 AM
LR03NJ's Avatar
Its a long shot, but i wojld like to use the auxiliary fan directly. I know its working but i would rather have it work sooner than waiting until the engine gets really hot. Also in the process, do i need a relay for that factory fan? I got an inline themostat switch to turn the fan on at 190 degrees. Thanks
Gerry
Old Jan 14, 2017 | 12:40 PM
Jeff Blake's Avatar
Whenever I tap into factory fuse boxes for power, I never actually draw power from it, I use a relay instead. Can the fuse box handle the power? Probably, depending on the fuse, but it opens up a can of worms that may cause problems later.
What I do, is put a 3 amp add-a-fuse in the factory panel (switched or constant, depending on what I want to do), wire the add-a-fuse to a busbar, and then wire the busbar to a relay that receives its power from an aux fuse box (self installed). That way the load of the unit comes from the self-installed fuse box that has adequate wiring from the battery.
Old Jan 14, 2017 | 12:41 PM
abran's Avatar
You need a relay, if not all that power will be running through the switch
avking
Nov 27, 2018 07:40 PM
arahim93
Mar 10, 2016 11:11 PM
sayre05
Jul 10, 2008 07:10 AM
yarddawg
Feb 8, 2008 06:28 PM
2k2wranglerx
Jun 30, 2006 09:44 AM
