LR3 Low Coolant...even though everything replaced...
Old Oct 8, 2023 | 08:21 PM
Philip Chan's Avatar
Default LR3 Low Coolant...even though everything replaced...
Had a low coolant warning for a while - assumed it was the sensor. Replaced the sensor...still low coolant warning (?!). Assuming the replacement sensor is good (?)...
Strange thing is - I googled this and one way to deal with this is to remove from the CCF. I went to check this via the GAP tool...it was already disabled! yet I still get the message...!
Any ideas?
Old Oct 8, 2023 | 09:21 PM
DakotaTravler's Avatar
The sensor is not the issue, the float inside the tank is which is not replaceable. This comes up rather often and the only solution is a new coolant tank. I recommend OEM or quality since there have been at least two cases I know of where a cheap one split open.
Old Oct 8, 2023 | 09:52 PM
Got it. Darn...thought this would be easy (er)...
Thing is, why is it still showing the warning even though it's been erased from the CCF?
Old Oct 8, 2023 | 10:27 PM
CCF does not matter, the fault for coolant is essentially hard-wired since it is critical.
jahummer
LR4
Sep 11, 2023 07:14 PM
ljdiscovery
Sep 9, 2016 05:28 AM
Rover72
Dec 13, 2010 06:18 AM
MikeLi
Sep 18, 2008 10:33 AM
Max_A6
Mar 5, 2008 08:52 AM
