LR3/LR4 same compressor cover?
Do the newer AMK compressors use the same black outer cover as the older Hitachi? I have just sourced a nice used AMK assembly with bracket but I'm not sure if I can use the old box, or if the mounting holes line up. I will also need a few more parts. I believe there is a tubing conversion kit that comes with the new compressors to covert from Hitachi to AMK. Does anyone know where to get the tubing kit?
I don't think the covers are the same as the AMK kit I received had new covers. I'm not sure if there is a separate part number for the bag of adaptors, your best bet is probably the parts counter at your local LR dealership. You would probably also want to have a set of the captive nuts on standby - I didn't need them but I have heard tales of rusted in threads needing to be busted out. It’s a pain when the whole job comes to a halt because of 50c worth of hardware...
And if you need step by step see this guide which I followed http://www.disco3.co.uk/forum/topic84165.html
That's not surprising, when you buy the complete "kit" it often works out cheaper than piecing it out...not logical I agree but that's the market for you...and they're probably the only game in town unless you fancy custom tube making and bending. If you got a good enough discount on the compressor alone, then that may make it worthwhile. Or maybe not.
Taken19
11-30-2014 02:20 PM
arnottdoug
11-19-2014 05:56 PM
arnottdoug
11-14-2014 12:58 PM
jjcooperz
01-24-2007 01:51 AM
