lr3 not starting
lr3 not starting
hello all,
I own a 2008 LR3. At times it would start with no problem. now it will start when it wants to. Sometimes I can drive it all day with no problems. Then I can go out and it wont do anything. However, I will get HDC fault, Suspension Fault and everything else coming on. If it happens while I am driving the air will stop working and then the radio will go off. then the flashers will blink but I can drive it. Once I turn it off, it may not start for days. I have spent over 3 thousand at the local dealership for a new key fob and some sort of junction box. they called and said it was fine and then the problem returned. I do not want to put another dollar into this thing but I like it a lot. what could possibly be the problem???????
I would take it back to the dealer, they said they fixed it. They did not. But I will say the junction box connectors are HELL to get right, its very tight back there. Its possible that one connection is not fully seated/locked. And I do know that when one or more are not, the truck will not start.
LR3 not starting
jbullock78
07-29-2024 01:59 PM
