lr3 not starting
Old Nov 2, 2020 | 06:51 PM
ceodom1's Avatar
4th Gear
Default lr3 not starting
hello all,
I own a 2008 LR3. At times it would start with no problem. now it will start when it wants to. Sometimes I can drive it all day with no problems. Then I can go out and it wont do anything. However, I will get HDC fault, Suspension Fault and everything else coming on. If it happens while I am driving the air will stop working and then the radio will go off. then the flashers will blink but I can drive it. Once I turn it off, it may not start for days. I have spent over 3 thousand at the local dealership for a new key fob and some sort of junction box. they called and said it was fine and then the problem returned. I do not want to put another dollar into this thing but I like it a lot. what could possibly be the problem???????
Old Nov 2, 2020 | 07:52 PM
houm_wa's Avatar
Default Old thread??
Looks to be original. You need to check for codes.
Old Nov 2, 2020 | 08:03 PM
ceodom1's Avatar
4th Gear
typing as I was reading an older thread.
Old Nov 3, 2020 | 06:37 PM
DakotaTravler's Avatar
I would take it back to the dealer, they said they fixed it. They did not. But I will say the junction box connectors are HELL to get right, its very tight back there. Its possible that one connection is not fully seated/locked. And I do know that when one or more are not, the truck will not start.
Old Nov 3, 2020 | 10:07 PM
ceodom1's Avatar
4th Gear
Default LR3 not starting
thanks for the info. It is still at the dealership. Been there since late august.
KKN
Jun 23, 2013 12:04 AM
hournet562
Feb 4, 2011 04:28 PM
gdebruijn
Oct 11, 2009 09:30 AM
BLeever
Jul 29, 2009 07:36 PM
