LR3 pulsating at idle
Old Mar 13, 2016 | 05:30 AM
jeremandre's Avatar
8th Gear
Default LR3 pulsating at idle
I own a v8 disco three . Whenever I start the car in the morning the engine pulsates . However this only occurs at Idle. I've heard everything from it needs a new fuel pump to the timing could be off or i i've heard everything from it needs a new fuel pump to the timing could be off or a vac issue. Anyone else experienced this ?
Old Mar 13, 2016 | 10:52 AM
chubbs878's Avatar
You may get more responses posting in the LR3 forum
Old Mar 14, 2016 | 12:47 PM
WNYErikDiscoII's Avatar
Former Sponsor
Are the RPM's fluctuating?
If so, clean your throttle body. Should solve it.
Old Mar 14, 2016 | 03:46 PM
jafir's Avatar
Moved to LR3 section.
Old Mar 14, 2016 | 04:17 PM
Lr3mcclung's Avatar
mine was pulsating at idle, I cleaned the throttle body and it solved it.
Old Apr 8, 2016 | 04:32 PM
scader's Avatar
I had my fuel line cleaned and it fixed my pulsing idle (imagine that included the throttle body as others noted).
TRIARII
Oct 14, 2013 10:33 AM
94svt50
Sep 4, 2011 06:58 PM
jus_flyin
Aug 1, 2011 10:56 AM
jmt
Oct 10, 2008 04:51 PM
