LR3 rear diff software update for P186D - Transmission Fault
Old Oct 27, 2019 | 11:07 PM
DakotaTravler's Avatar
Default LR3 rear diff software update for P186D - Transmission Fault
Anyone familiar with this one?
https://static.oemdtc.com/TSB/LTB00228NAS4.pdf
I have been getting this error when taking the truck into situations where the rear diff would need to lock. Upon reading, some just replaced the rear motor. I guess there is one place to get them that does not require a recalibration or such. The other option, which I want to do, involves the software update above.
So question are about the GAP tool. Can it push this update if I get the file from them? And can the GAP tool recalibrate the diff incase I do swap the actuator motor? I dont have the tool, but really need to get one soon. If no one has an answer, I will contact the makers of the tool. Thought I would ask here first to get hands on input.
Old Oct 27, 2019 | 11:11 PM
To the best of my knowledge it can. Abran would know better than I
But remember you should always take it to the dealer...
Old Oct 27, 2019 | 11:22 PM
Oh yeah right, I dont want to void my warranty!!
Old Oct 28, 2019 | 12:27 PM
abran's Avatar
Gap does the calibration and they can provide the software if needed.
I have only ever recalibrated without issue.
Old Oct 28, 2019 | 12:49 PM
houm_wa's Avatar
....any noises from your diff? If you are just replacing the locking motor, you should be sure your clutch packs aren't compromised. Mine was making a "clunk" sound in some cases as a result of the actuator going out. I wound up replacing both.
Old Oct 28, 2019 | 07:22 PM
I dont think there is any noise, at least not regular. Its just when I am in the mud with a program that can operated the rear locker I get the occasional fault about reduced traction. I do not use the rear diff a lot at all, but the problem seems to be getting a little worse. So when doing research, I found that TSB file. I actually have no clue how to find out if the software update was done already, I assume not even though it has a long history of LR dealer services. At one time I did hear a loud clunk, sorta metallic ring or such. Which from what I read can be another sign but it could have been a number of things that caused it. Maybe the same sound you heard. Hard to say. For now I am just not using the rear locker.
So I figured I would update first to see if the code still comes up. If it does, then I will replace the actuator motor. Also I guess one can read clutch life in the diff with the tool? Not sure how accurate that is or how its calculated.
Old Oct 28, 2019 | 09:27 PM
houm_wa's Avatar
The clunk I heard was pretty easily reproduced. I'd just put it in a program where I'd expect the locker to lock and load it somehow like a turn or I think taking it on the dealer's off-road "course" produced it.
How would you not use the locker? You mean keeping TR in the General setting?
Old Oct 28, 2019 | 09:29 PM
Yeah, I just keep it in the normal mode - no special programs.
Old Oct 29, 2019 | 12:21 PM
houm_wa's Avatar
That must really hamper your off-road ability, though....what has been your experience? More TC engagement? I'd think Normal mode would made it such that your center diff rarely locks up too.
Old Oct 29, 2019 | 12:27 PM
I think in normal nothing locks, including the TC. But the truck does really well. Went up a sand dune last weekend with no issue.
