LR3 rear will not lower
Old Jan 5, 2016 | 05:07 PM
  #21
jsccinc's Avatar
I recently noticed that it will adjust itself to normal height, not really sure what that is at this point, when it's first started. The left front starts to drop first then the right front and eventually followed by the back. It appears to drop to access height. It slowly drops while driving but I always have a suspension fault so the compressor won't come on to maintain pressure. It's usally only a matter of time before the amber susp warning light turns red. I'm thinking it's time to start checking for leaks. Is there any way to bypass the compressor and pressurize the system manually? Or could it still be an electronic issue?
Old Jan 5, 2016 | 07:34 PM
  #22
houm_wa's Avatar
Default Red Suspension Faults
Red suspension faults usually mean a sensor out of calibration or a toasted compressor. If you do a hard reset to clear the faults you could exercise the compressor and rule it out. After that it's simply a calibration. You can go to the dealer and pay $200 or you can buy an IIDTool for $400 and do it yourself. My suggestion is the latter. If you are going to keep this vehicle you should have a GAP tool.
Old Jan 7, 2016 | 09:02 AM
  #23
TOM R's Avatar
There was a thread here about manually pressurizing the system for diagnosis and it is not easy to do iirc
Plus the suspension constantly makes adjustments so without the compressor running kind of screwed
Another water ingress with a rover service bulletin is the a pillar covers, pull the covers, remove the locator pin at top seal hole in body for that pin, then Rtv around the other holes where the body clips push into and snap cover back on
Iirc the cowel must be removed so this is also a good time to make a water deflector for the hvac intake
In the end you may be stuck with going to a dealer or at least an Indy shop, when we bought the lr3 we bought a decent scanner because I do all my own work and knew there would be issues, it has payed for itself over and over,only time I have had this rover to dealer was for a full alignment
Old Jan 7, 2016 | 10:20 AM
  #24
cmb6s's Avatar
Other way around... pillar covers must (should) be removed in order to remove cowl, but the pillar covers themselves just pull straight off.
Old Jan 8, 2016 | 10:57 AM
  #25
TOM R's Avatar
I could not recall the order in my head lol, either way these are leak points to address before they become an issue, self explan the problem once you take it apart
nh9095
Jan 14, 2019 12:36 AM
LADEROUTE
Sep 1, 2012 05:06 PM
matt5963
Jun 26, 2012 10:48 PM
Wilky1978
Mar 13, 2012 02:45 PM
fastrx7man
Jan 28, 2012 12:49 PM
