LR3 replacement key, any rechargeable?
Old Jun 29, 2020 | 09:51 PM
DakotaTravler's Avatar
Default LR3 replacement key, any rechargeable?
There are like 1,000 key threads. I thought one mentioned there was a seller with a key that was priced decent AND worked with the rechargeable induction circuit in the column. Can't find it. Also sellers come and go.
So... is there an aftermarket option for replacement keys that have a working rechargeable circuit? I use my remote far too much to have a regular battery, its not an option. If I have to go dealer I guess I will.
Old Jun 30, 2020 | 01:02 AM
5280LR3's Avatar
An option if you can't find a new board with the charging circuitry...
https://www.ebay.com/itm/Unlock-Refl...A/382285043806
I found this service a while back. I have a couple OEM fobs if you're interested. (not reflashed or wiped)
Old Jun 30, 2020 | 11:28 AM
rovers3's Avatar
Do a google search for LR3 remote battery replacement. Hardest part is to remove the old case, but it is easy to do if you can solder. I did this on my old 2005 and it worked fine for 3 more years till I sold it.
Old Jun 30, 2020 | 12:26 PM
douglastic's Avatar
The cheap key I bought on eBay for ~$14 was indeed rechargeable
Even had a Panasonic battery installed
Land Rover Discovery Keyless Entry Key Fob Remote Uncut Folding Flip 315MHz
112336273935-1835007816001
SOLD BY
alice2017-us
Unfortunately, this exact item is no longer available from this seller - but I am sure there are others out there!
Maybe this one? Panasonic and charging magnet seen in pics.
https://www.ebay.com/itm/For-Land-Ro...item3b12cd9425
Old Jun 30, 2020 | 01:15 PM
douglastic's Avatar
found one from the same US seller I used before ~$18
https://www.ebay.com/itm/Keyless-Ent...1/112644666926
^^ in fact - I just bought one myself ^^
When it comes, I can upload a pic of the internals here if you like
Old Jun 30, 2020 | 07:39 PM
@rovers3 - I know how to change the battery, I have done it before. What I need is a second key to program and I would like it to be rechargeable. I will alternate usage between keys.
@douglastic - Let me know. Seems many come with that battery but lack the circuitry for recharging. So unless its known that they are rechargeable I have to assume they are not.
Old Jul 9, 2020 | 10:30 AM
douglastic's Avatar
@DakotaTravler
Update: got the new key and opened it up. first impressions:
- battery is generic, but stamped "rechargeable" with visible charging magnet
- no battery cradle like previous (or OEM)
- overall nicer case than the previous key from same seller
Is there any way for me to easily test or prove the rechargeable function?
My wife has the LR3 out today, so will code tonight and will report back if coding failed - otherwise assume all was good.
First pair of pics are of new key, second pair are the previous one that died.
New key battery
New key circuitry
Previous key battery
Previous key circuitry
Old Jul 9, 2020 | 06:44 PM
Thanks very much for the update, bought one just not to try out also. If good I may get a couple more backups to keep around and unprogramed.
Old Jul 9, 2020 | 06:52 PM
douglastic's Avatar
You bet.
I had also though about a backup . . .
What do you think the "usable life" is left of the battery, if it sits around unused for a year or 2?
Old Jul 9, 2020 | 07:38 PM
loanrangie's Avatar
Originally Posted by douglastic
You bet.
I alternate usage of my keys to keep them charged, should get an induction charger for home use.
