LR3 tailgate
Old Oct 1, 2022 | 07:13 PM
mroorda's Avatar
Default LR3 tailgate
This is a well know well-documented issue but my problem seems a bit nuanced. My back tailgate will not open from the button at the license plate light. I hear the tiny click from the microswitch inside. No actuator sound. When I press and hold 3 seconds the lock/unlock buttons inside by the radio (failsafe method), the upper tailgate will open (if someone else pulls while I press the buttons). So, we've proven the actuator works and the cable is connected. Also, the bottom gate opens normally once the top is open.
This leads me to believe the problem is the switch (near the license plate light). So, I disassemble the switch and it looks fine inside. I even use my ohm meter and can see continuity between the two legs of the switch when I click it. This means the switch is physically opening and closing the circuit as it should. Either way, I cut off the switch and sort of expected (hoped) that when I touch the two wires together it would activate the actuator, but no.
Maybe it could be the harness between the switch and the actuator? Maybe the actuator could be marginally working and the failsafe method provides more power than the normal switch? I'm grasping for straws now. I do have the lower gate torn apart too so I have access to the actuator and all the connections. When My new switch shows up I will connect it and if it still doesn't work (I don't expect it to) then I will order a new actuator and maybe one with a harness.
Any thoughts?
Thanks! -Matt
Old Oct 2, 2022 | 07:17 PM
DakotaTravler's Avatar
I believe the connector for the switch is up in the headliner behind the plastic panel at center with the light on it. Pull that off and inspect. I believe you can jumper the actuator there also for testing so then you can maybe see where the issue is.
Old Oct 3, 2022 | 01:22 PM
mroorda's Avatar
I will give it a shot. Thanks!
Old Oct 29, 2022 | 09:00 PM
mroorda's Avatar
Just a bit of followup...I found a broken wire inside the upper lift gate. The insulation was still intact but the very stiff conductor was obviously broken. Had to remove the outside license plate light housing and the inside trim below the window. Actually, I removed a LOT of trim and various stuff before getting to this point. One other thing...in the process, I replaced the actuator. Glad I did it even though the original was not the problem. The new one is much more powerful and reactive. The interesting part is that I used a part for the Ford Festiva. Exact same actuator but you need to use the old frame. ~$15 vs $100 for the LR part. 2S6T432A98AE Tailgate Central Lock FOR Ford Fiesta V Mk5 2.5L 3.0L l4 V6 2002-10 | eBay
Athana
Sep 18, 2023 06:20 AM
malibumike
LR4
Oct 4, 2022 10:15 PM
Fiminod
Apr 9, 2014 04:09 PM
ktm_525
Sep 4, 2012 10:43 AM
Ozzie Owl
Jul 19, 2009 10:00 AM
