LR3 Tire Pressure Monitor
Pretty sure you can just drop the front visors, a pillar trim, handles and center light assembly and lower it just enough to access it. Black module with a blue and green connector and more wires than one would think there should be. Siemens or VDO brand usually and should say 315 Mhz on it. Stupid location really since itself has no antenna and does not need to be where it is. Im disabling mine, it was handy to have and saved my butt a couple times but my new wheels have no sensors installed.
Remove the outside second row handle and the second row center light, you can reach TPMS box by slightly pulling down on the outside of the headliner while reaching in from the opening for the light. It is to the left. It has 2 8mm nuts holding it in place. One is easy to get to the outside one not so much. Good thing is it it will be fine with just one nut holding it in if the outside one is just too hard to get started.
It helps to have a small flashlight that will fit up above the headliner just in front of the light opening and ratchet type wrench.
At least that it way I did it (more then once)
Hope this helps. Let us know how it turns out.
Jeff
Jeff
