LR3 Tire Pressure Monitor
Old Feb 21, 2022 | 02:42 PM
Capitalman1's Avatar
8th Gear
Default LR3 Tire Pressure Monitor
Hello all:
Can someone please tell me where exactly the Tire Pressure Monitor is located on a 2006 LR3? I am getting conflicting information.
Many thanks.
Old Feb 21, 2022 | 03:27 PM
DakotaTravler's Avatar
Above your head, near the middle (for second seats) light assembly. But I dont think removing the light assembly will give enough access.
Old Feb 21, 2022 | 03:42 PM
8th Gear
I actually had that light out previously to look at the Sun Roof Monitor but didn't see anything else there?
Old Feb 21, 2022 | 03:43 PM
Pretty sure the sunroof motor is up front. Or is it in back? Either way I did mention having the light out would probably not give access. Have to drop the headliner a bit.
Old Feb 21, 2022 | 03:59 PM
8th Gear
It was the Sun Roof Monitor I was working on but didn't have to drop the Headliner to access it. Guess I have to drop it now to try to find the TP Monitor. Thanks for the input, appreciate it.
Old Feb 21, 2022 | 04:04 PM
Pretty sure you can just drop the front visors, a pillar trim, handles and center light assembly and lower it just enough to access it. Black module with a blue and green connector and more wires than one would think there should be. Siemens or VDO brand usually and should say 315 Mhz on it. Stupid location really since itself has no antenna and does not need to be where it is. Im disabling mine, it was handy to have and saved my butt a couple times but my new wheels have no sensors installed.
Old Feb 21, 2022 | 04:08 PM
8th Gear
Great, thanks again.
Old Feb 21, 2022 | 05:12 PM
Rufflyer's Avatar
Remove the outside second row handle and the second row center light, you can reach TPMS box by slightly pulling down on the outside of the headliner while reaching in from the opening for the light. It is to the left. It has 2 8mm nuts holding it in place. One is easy to get to the outside one not so much. Good thing is it it will be fine with just one nut holding it in if the outside one is just too hard to get started.
It helps to have a small flashlight that will fit up above the headliner just in front of the light opening and ratchet type wrench.
At least that it way I did it (more then once)
Hope this helps. Let us know how it turns out.
Jeff
Old Feb 25, 2022 | 11:19 AM
8th Gear
Hi Guys:
I got it. Was kind of a pain to get it out but your instructions helped a lot. Thanks for the help, really appreciated.
Laurie Pope
Oct 10, 2019 10:53 AM
merlinj79
LR2
Jun 28, 2017 07:46 PM
Silver_Slug
Aug 2, 2013 07:05 PM
_Chris_
Feb 9, 2010 11:19 PM
oncorhynchus
Jan 21, 2007 02:14 PM
