LR3 V8 4.4 Dip Stick Tube is Cracked..
Old Dec 8, 2022 | 05:15 PM
Athana's Avatar
Default LR3 V8 4.4 Dip Stick Tube is Cracked..
Hi the mechanic smoked the engine as I've had a check engine light on for a long time but car runs excellent.So the Dip Stick Tube has a hole in it.I tried Atlantic British and they don't have that part.
Any suggestions where to get an OEM quality one ?
Thank you
Old Dec 8, 2022 | 05:47 PM
DakotaTravler's Avatar
FYI there are a couple versions, so make sure you compare the old with new. Double check, but I think the part number for 2005-2009 is LQM500030. A search should bring up sellers, such as AutoHaus or Parts Geek which both have genuine. They are not cheap at about $70 USD. Kinda surprised AB does not have em.
Old Dec 9, 2022 | 07:14 AM
Athana's Avatar
hi Dakota that seems to be the part number for the dip stick itself not the dipstick tube.: (
Old Dec 9, 2022 | 07:15 AM
Ope! Read that wrong. Not used to people needed the tube. If the mechanic smoked it, tell the mechanic to find one.
Old Dec 10, 2022 | 04:36 AM
Athana's Avatar
Ok : )
Old Dec 10, 2022 | 01:27 PM
tracyc's Avatar
Depends on whether by 'smoked it', you meant they did a smoke test on it or they broke it If they broke it, then sure, let them make it right. If they just found it w a smoke test, then if it were me, I'd find a used one to install.
Old Dec 11, 2022 | 12:42 PM
Athana's Avatar
Yes Ive been having a Check Engine light for most of the year but car running excellent and he said it was nothing serious. I wanted it solved as we took it in for other things so he Smoke Tested Engine and there is the leak.
Since I can't find one he is going to repair the old one. Whew thank goodness I can't believe the part is not findable for a car that was last made only in 2009.
Old Dec 12, 2022 | 05:56 PM
Well we need the part number to find the part, I am sure it is available.
Old Dec 12, 2022 | 06:58 PM
douglastic's Avatar
https://parts.landroverpalmbeach.com...6/4536872.html
Old Dec 13, 2022 | 09:18 AM
Athana's Avatar
When you go to it it says not available: (
