LR3 will not lower to existing height
Old Nov 26, 2017 | 07:50 AM
Curtis Hudson's Avatar
3rd Gear
Default LR3 will not lower to existing height
My 2008 LR3 will not lower to exit height. It will rise up to extended height and also it will lower to driving height. No suspension fault light is not on. What could be the problem?
Old Nov 27, 2017 | 03:11 PM
houm_wa's Avatar
Default Huh?
I'm going to assume that exit height = access height and extended height = off-road height. So, what does the LR3 do when you try to select access height? What messages do you get?
Old Nov 28, 2017 | 09:48 PM
3rd Gear
It will move up to off-road and lower to road height. It will not lower to access height. The compressor works, it also adjust to the road. I'm at 140000.
Old Nov 28, 2017 | 09:51 PM
3rd Gear
No message come up when I lower it. Only when I put it in off-road and driving height
Old Nov 28, 2017 | 11:16 PM
abran's Avatar
Switch is bad.
Old Nov 29, 2017 | 11:57 AM
houm_wa's Avatar
Yeah that's what I was going to suggest as well...but Abran's diagnosis is worth 10x more than mine.
Old Nov 29, 2017 | 07:38 PM
abran's Avatar
^ only 10x? Jk.
I’ve had switches that will not go the normal height from off road but when forced to go to normal height would go to access height via the switch.
so I’m assuming your problem is the same... but different.
jsccinc
Jan 8, 2016 10:57 AM
LeethalG32
Aug 18, 2012 06:05 AM
lyleorszulak807
Oct 17, 2010 11:07 PM
