LR3 Windshield Washer Jet Issue
Old Jul 11, 2013 | 12:22 PM
churious's Avatar
Default LR3 Windshield Washer Jet Issue
Ok so last year I had the washer jets stop working under hot heat. Figured out it was the 10amp fuse via the link below so i put in a 15amp and its worked fine for a year.
MyRovers.com » LR3 Washer Fuse
Fast forward to this week.... 90 degree weather and long driving the 15 amp breaker pops. I replace it and it immediately pops again. Tried some higher amp fuses just to see and they all blow.
Is it the washer motor? A short? Thoughts?
Old Jul 14, 2013 | 03:56 PM
churious's Avatar
Also.. does anyone know where the washer motor is located for the windshield washers?
Old Jul 14, 2013 | 10:15 PM
er1c's Avatar
It's located under the windshield cowl. (The plastic piece that runs along the bottom of the windshield.) It has plastic clips holding it in. I seriously doubt it's the wiper motor causing the issues though.
Old Jul 15, 2013 | 08:58 AM
churious's Avatar
Not the wiper motor. The washer fluid motor or does the wiper motor send this fluid?
Old Jul 15, 2013 | 09:26 AM
roverguy7's Avatar
Washer motor is in the bottom of the washer fluid tank. There are two motors, one for front/rear, and one for headlights. The one you want will have two hoses coming off of it.
Alejandro Mx
Member Group And Special Buys
Feb 14, 2015 07:58 PM
astarrdemille
May 21, 2013 01:57 PM
srockrae
Mar 11, 2013 05:08 PM
philipisland
Feb 4, 2013 07:13 PM
krazzz
Jan 15, 2010 07:17 AM
