LR3 Won't start, just one click
Old Jul 10, 2015 | 03:51 PM
zenarcher's Avatar
6th Gear
Default LR3 Won't start, just one click
So, I changed the alternator last night, and now she won't start...I did have one short with a spark during the swap. Here is what I have done so far:
1. charged the battery and had the battery load tested and its good
2. swapped out the Starter relay with one that works, and checked all the relevant fuses.
3. The battery terminals are clean and tight, and I checked the ground and it's tight as well.
4. tapped on the starter while someone tried to start car
When I turn the headlights on and try to start it, I hear the single click and the headlights don't dim at all.
Can anyone help? I'm close to throwing in the towel and calling a tow truck...
thanks!!
2008 LR3 SE V8
Old Jul 10, 2015 | 04:28 PM
cmb6s's Avatar
How did you have a short with a spark? I seriously hope you disconnected the battery before attempting to swap the alternator. Regardless, fuses, fusible links and relays would be the first thing I would start looking at. My guess is that you blew something associated with one of the many ecus. Hopefully, it's just a fuse and you can find it easily.
Old Jul 10, 2015 | 07:51 PM
Nov15's Avatar
I recently fixed an issue similar to this in our LR3. The fix was to replace the positive battery cable end. There is a fusible link in there. Also had to clear faults and reset controllers. This was over my head so I took it to the mechanic. $700. I'm not saying this is the solution for your issue but it sounds exactly like what I had happening.
Disco Alan
Nov 21, 2014 09:21 AM
toad2
Jul 31, 2010 07:17 PM
beebe
May 25, 2010 09:24 AM
hilltoppersx
Jul 28, 2009 04:36 PM
