LR4/LR3/RRS Center Console Compatibility
Old Aug 15, 2017 | 12:20 PM
djkronik57's Avatar
Default LR4/LR3/RRS Center Console Compatibility
Just curious since my latch is broken on mine, would this part listed for a RRS/LR4 fit the LR3? Does anyone know if the center console is any different?
NEW! Range Rover SPORT/LR4> Console/Cubby box base w/Noble Chrome Latch | eBay
Old Aug 15, 2017 | 02:37 PM
Geo's Avatar
Geo
Looks very similar from the photos on the listing.
However, I was able to repair the latch. There's a pin/rod that slides to the side and the plastic nub breaks off. I put some plastic epoxy on the broken end of the nub and around the joint. Works like a champ. All the parts were captive, so nothing was lost. Be sure to get everything together correctly before you epoxy as the rod may no longer be able to slide out.
If you can take it apart to replace the pan, I'm confident you could fix it!
Old Aug 15, 2017 | 03:05 PM
djkronik57's Avatar
I actually did fix it, but the fix only held up for about a year. Looks like I'll either have to keep gluing or see if this part works.
Old Aug 17, 2017 | 04:10 PM
Rufflyer's Avatar
Default I took a different approach
I took a piece of aluminium cut it to fit around the post and bent it on both sides until it would latch to the console, then glued it with contact cement to the spring loaded lever.
Jeff
Attached Thumbnails LR4/LR3/RRS Center Console Compatibility-20170817_160416.jpg
Old Aug 17, 2017 | 04:50 PM
Geo's Avatar
Geo
Nice! I had not realized those broke off as well.
unseenone
Dec 14, 2017 01:44 PM
EstorilM
LR4
May 1, 2017 01:37 PM
LR3inCanada
LR4
Sep 12, 2015 10:19 AM
WNYErikDiscoII
Dec 23, 2012 11:23 PM
perkj
Jul 30, 2011 07:20 PM
