Metal trans pan vs OEM pan
Old Feb 7, 2017 | 03:30 PM
abran's Avatar
Default Metal trans pan vs OEM pan
I tried to be a precise as possible.
1- drained OEM pan for 14 hours into a bucket from drain plug
2- dropped the pan on the support and drained for another 2 hours.
3- removed the pan and drained into same bucket for a day
4- when filling with metal pan I captured all spillage and subtracted from amount filled.
conclusion:
Drained 5.75 quarts from OEM pan
Filled metal pan with 6.25 quarts
Old Feb 8, 2017 | 06:27 AM
LR Techniker's Avatar
I never had proof, but I always suspected the difference was negligible. Now we know.
Old Feb 8, 2017 | 11:47 AM
houm_wa's Avatar
Soooo.....does that mean that the tranny was 1/2 a quart low before you did the service? If not, how did you fit more fluid in there????
Old Feb 8, 2017 | 11:58 AM
Good catch, I misread that. I subconsciously swapped the two figures and assume the metal pan held 1/2 liter less.
Old Feb 8, 2017 | 12:05 PM
abran's Avatar
A- trans was low on fluid (no visible leaks but maybe there is some "consumption")
B- metal pan has more capacity
C- All of the above
As I mentioned before the metal looks to have more volume.
I'm voting for C. But either way, the difference is neglible.
Old Feb 8, 2017 | 02:25 PM
houm_wa's Avatar
This is good data, Abran. Thank you. If it's not too much trouble, could you (and anyone else doing these somewhat routinely) continue to collect this info? If we get enough data points, we can answer your question above succinctly as A, B or C.
Old Feb 8, 2017 | 03:47 PM
abran's Avatar
Sorry, but the hassle of collecting the fluid, measuring old fluid in my pump, etc. Is s hassle.
I'm convinced.
I did my duty, who's next?
Old Feb 8, 2017 | 03:54 PM
abran's Avatar
A better way to test would be to take an OEM pan, place on flat surface and fill with fluid to the lip of the pan. Then take that fluid and drain into the metal pan with filter sitting in the pan.
My plastic pan was already picked up by our recycling service. Next one I do I can do that, or if someone wants to send me an OEM pan I will do the comparison.
Old Feb 8, 2017 | 08:22 PM
houm_wa's Avatar
Fair enough, Abran...and I agree your revised experiment will lend even more reliable results. I am in no rush, and do appreciate your efforts. Virtual-beer for you!
Old Feb 8, 2017 | 08:41 PM
TOM R's Avatar
How much car did you disassemble to service the trans, we are about due
