Misfire on deceleration
Old Feb 23, 2025 | 02:14 PM
CantComplain's Avatar
Default Misfire on deceleration
Hey All-
Recently had a CEL for misfire. As part of troubleshooting and resolving, I had the GAP tool set up for tracking misfires on cylinders 1-8. Easy peasy, and misfires would follow what turned out to be a bad coil. Quick count up to 255, then re-setting every 30 seconds or so and doing it again. I assume those intervals and that max # are baked into the GAP tool somehow.
Anywho, once I replaced the coil I kept the misfire screen up on a decent drive over a ~7200' pass where the CEL/problem had first shown. I noticed that when I decelerated to come to a stop in town that I'd consistently get 1-3 misfires on #8. Stayed as I idled at the light, then zero'd out once I went 100 yds or so. Decelerating on a hill would be most if not all cylinders at 1 misfire. Either way it would reset after the 30 seconds or so but was relatively repeatable.
A few misfires seems like no big deal, but the ones at a slightly higher rate on #8 make me think something may be going on. Any ideas or should I just shrug it off? Presumably it's been doing this all along and I just wasn't watching the misfires. It's a different cylinder and bank from the original issue. Quick google leads me to think maybe a small vacuum leak but not sure why it would be specific to a single cylinder.
2006 LR3 with 127k
Old Feb 23, 2025 | 04:28 PM
DakotaTravler's Avatar
How old at the spark plugs? Did you clean the MAF? You could have multiple tiny issues with the col being the big one that is now fixed. I never really looked at mine to see if low numbers of misfires are somewhat normal or not, but I would expect not. And yes, generally a vac leak does not cause an issue with a specific cylinder. But it can happen if there is a leak at the intake itself where it interfaces the head.
Old Feb 26, 2025 | 02:15 PM
Thanks for the input. Probably 5k on the irridium plugs, clean MAF, clean throttle body, running 76 premium, fresh-ish oil, and generally well-sorted at this point. I'm not going to fret much on it because it's running well, but I'd be super curious if anyone has a saved "live values" screen (like I now do) with all of the cylinders with the misfire count.
Old Feb 27, 2025 | 02:20 PM
rich.cash's Avatar
My misfires were injector related. Replaced them, and issue went away. I've checked sporadically on the GAP tool and haven't had misfires show since. I did the usual as listed above before moving on to the injectors to resolve.
newdude
LR4
Apr 29, 2026 12:12 PM
flyer08
Oct 11, 2022 11:52 PM
TheSloth
Aug 1, 2017 11:57 AM
maxman
Dec 28, 2010 08:40 AM
dammad
Nov 10, 2010 04:55 PM
