Mysterious red/green wired connector
Old Jan 2, 2019 | 05:46 PM
Rhino007's Avatar
So the shop put it on their magic computer and pulled the following codes: p0730 and p0735
then they said they looked at the Land Rover TSB that stated if those 2 faults are indicated, replace transmission.
Old Jan 15, 2019 | 02:14 PM
Rhino007's Avatar
I have now moved my truck to another shop that said it was low on tranny fluid and also has a leak at the cooler hose. So they think that is the reason my truck is pulling those codes is due to low fluid and a small leak. I hope so.....it's costing me about $1400 total for fluid change, pan and hoses.
Old Jan 17, 2019 | 05:49 PM
SixesnSevens's Avatar
Originally Posted by Rhino007
... I also need to figure out how to get the navigation system working (says "navigation not fitted") I tried another DVD drive, but no luck. So my next move will be to remove the panels to check the wiring there since I don't know how long rain water has been dripping inside that passenger side panels.
I had the same issue, "navigation not fitted" and was sure it was the DVD ROM since it appeared to be dead and wouldn't eject the disc. Instead it was a single wire that corroded at the connector. Connector is behind the panel in the passenger footwell. After splicing the bad wire the Nav has been perfect.
Old Mar 13, 2019 | 01:23 PM
Rhino007's Avatar
The fluid change didn't fix it, so they installed a new transmission. All is good with it now. Next maintenance after I recover from the transmission cost....will be the prop shaft center bearing.
Alex J
Oct 26, 2025 09:33 PM
DakotaTravler
Feb 11, 2022 11:35 AM
Toran
Sep 20, 2018 10:24 AM
cgap
Dec 4, 2011 12:18 PM
jayzoid
Nov 27, 2011 04:07 PM
