I haven't ordered it yet but figured instead I would ask the community if anybody has direct experience or just what I should expect? I've put stereos in cars before but it's been awhile. And nothing this complex.
I have the Logic 7 in the LR3. But no blue tooth.
Thanks for being kind! New member here and excited to meet fellow LR enthusiasts!
Reason: Added video link
well, the manufacturer said they don't have a canbus interface that fits this, but I am a bit confused. Anybody know if there is a generic canbus adapter for LR3 that would work for this?
Then I would be more worried about the MOST network. Does it plug into the MOST network? You probably dont need the CAN bus hooked up the radio unless the radio can operate on the can buss at the proper speed/frequency of the LR3. You may have to install an aftermarket AMP and all that stuff too, basically you will have to build it up from speaker wiring to the head unit.
I think I could deal with that. Here is the back of the unit. I would need to remove the current amp, correct?
Anything you remove on the MOST network would need a bypass plug. Cheap ($5) on eBay. Keep in mind certain things talk to each other over the network, so removing stuff may disable others.
