New 05 LR3 Aftermarket Stereo Project
Old Feb 19, 2020 | 11:36 PM
loanrangie's Avatar
You will lose the satnav/4x4 info when you replace the head unit plus any function that uses the factory stereo to adjust, there is a CANbus compatible harness available but i've heard conflicting info on how well it integrates. Mine is an SE which had the base stereo so my android install was easy and only lost the clock on the dash.
Old Feb 19, 2020 | 11:43 PM
DakotaTravler's Avatar
You sure? When I bypassed my head unit sat nav and 4x4 info, etc., all worked fine. But I have the MOST network, if you have the base stereo then you have no fiber optic so maybe that is why?
Old Feb 19, 2020 | 11:49 PM
loanrangie's Avatar
No i didint lose anything as i didnt have satnav/4x4 info to start with but every post i see where a logic7 or high spec system seems to lose a lot of functions.
Old Feb 19, 2020 | 11:54 PM
Odd. Probably because they are not putting a bypass in the MOST loop. The instrument cluster is the network timer so as long as the loop is complete it should pretty much work. As for the CAN bus, there are two networks used by Rover and they are not at all compatible, which is maybe why some head units work and some dont, the data bit path must match.
Old Jul 2, 2020 | 07:47 PM
Loriebluedico5's Avatar
Can anyone give me a quick guide on how to bypass the MOST network so I can get my factory 4X4 and sat nav working again. 06 HSE with logic 7. I replaced the radio with a Pioneer. I bought the fiber optic cable off eBay. Just not sure where to start. Thanks
Old Jul 2, 2020 | 10:02 PM
You cant bypass the network, so not sure what you mean by that. If you removed the head unit, the bypass look you bought simply connect to the MOST connection. Pretty straight forward.
Old Aug 20, 2020 | 03:48 PM
LillyandAnnette's Avatar
Default 06 lr3
Hi! I recently bought my first LR3 2006 and am looking to do the same thing! How did the project turn out? Can you attach photos? Does the logic 7 still work?
I was also looking at a Tesla looking unit like this one:
https://a.aliexpress.com/_BU21K6
but wondering if it’s a mistake given that it looks like a lot of work to install and where would the emergency lights and door lock buttons go? Has anyone ever tried to install on of these radios to the LR3?
thank you for any info!
Old Aug 20, 2020 | 06:28 PM
I was unable to keep the logic seven factory navigation and off road information screen. I was told it could be done, but I couldn’t figure it out. But I still do really enjoy having CarPlay and this pioneer unit in the car. All the factory amp speakers and subwoofer work correctly. The steering wheel controls work as well.I kept all the original equipment so I could switch it back if I desire later.
Also in the process I removed the ashtray and installed a tough rock power panel. Which I really do enjoy. I Kinda don’t like staring at the Landrover splash screen I was trying to figure out something to put there in place of it but haven’t gotten there yet.
I also added a back up camera which I really enjoy. Also due to the orientation of the LR3 dash, I picked a pioneer unit that has a tilt out screen for better visibility when driving
Old Aug 20, 2020 | 07:53 PM
loanrangie's Avatar
That is the ugliest thing i have even seen in a disco.
Old Aug 26, 2020 | 04:15 PM
Edi's Avatar
Edi
Good afternoon, I have a 2007 LR3, I bought a new stereo but I can't find the cables to install, I bought the frame but the cables I'm having trouble finding, I would like to keep the functions of the steering wheel. would you have any tips on which cables to buy? Thank you
