New Key
Old May 31, 2022 | 11:36 PM
Whiteboard55's Avatar
Question New Key
I have a Disco 3. I purchased through Land Rover a new key. LR couldn't get it to start the vehicle. I have also tried 2 separate auto electricians. They both tell me that the vehicle recognises the key and the dashboard lights up but it doesn't start nore does it lock and open the doors if you press the appropriate button. Any suggestions why this is happening?
Old Jun 1, 2022 | 10:43 AM
douglastic's Avatar
Need more info - otherwise I will assume:
You bought the new $$$ key through a LR dealer, using your VIN, waited weeks for it to be shipped from the UK?
Why are they are not bending over backwards to make the key work for you?
Did they forget to program it?
Old Jun 1, 2022 | 04:38 PM
DakotaTravler's Avatar
If you have a GAP tool or similar, you can pull codes. If the key is not valid it will throw a code - actually my valid key occasionally throws a code too, but I digress. But other than that idea, what Doug said. If its not starting the vehicle, sounds like a bad key. The remote function is separate from the starting functions. The remote functions not working can actually be from bad programming OR a truck issue with a wire that commonly fails at a joint, forum is full of info on that repair.
Old Jun 1, 2022 | 06:54 PM
Thanks for this.
Key is a genuine LR from the UK with VIN. Key cut in UK prior to sending it. LR spent 90 minutes trying and in the end said that the equipment that they have (new dealership 3 years) was not really compatible with the older vehicles and I need to find some one or dealer that has a T4 coder. Think the best thing is to go back to LR and see what they are going to do. They should have a GAP tool.
Old Jun 1, 2022 | 07:23 PM
houm_wa's Avatar
They will NOT have a GAP tool.
The best thing to do is for you to get a GAP tool, then use it to program your key (paying for part of the cost of the GAP) and then living happily ever after.
Also, make sure they (the dealership) didn't take a red cent from you! It's asinine that they can't program a key FOB.
miguelalanis
Sep 19, 2019 04:42 PM
cmshoot
Jun 7, 2016 06:39 PM
cmshoot
May 23, 2016 09:28 AM
Grover11
Jan 31, 2012 07:10 PM
Discolife
Nov 25, 2011 11:38 AM
