New LR3 owner here
Old Feb 8, 2014 | 09:06 AM
abqrb2000's Avatar
4th Gear
Default New LR3 owner here
Just got my first Land Rover it's a 2006 LR3 SE V8 with 108,000 miles.
It is an amazing vehicle. I did a bit of research before buying and found the lower control arm bushing issue before buying and got a better deal.
I just ordered new front lower control arm assemblies.
The sunroof seems noisy at 50+ mph. Do the wind deflectors solve that issue?
These trucks have so many bells and whistles I am still finding stuff!
Old Feb 8, 2014 | 10:36 AM
jafir's Avatar
Do you have roof rack cross bars? I removed mine because they were noisy.
Old Feb 8, 2014 | 11:09 AM
abqrb2000's Avatar
4th Gear
Yes I do. Definitely seems to coming from the sunroof. Get louder if I lightly push up on it.
Old Feb 8, 2014 | 11:46 AM
LR Techniker's Avatar
How does the adjustment of the glass look?
The glass should be flush with the roof line. The leading edge must not protrude above the roof line at all and the trailing edge must not be below the roof line at all.
Old Feb 8, 2014 | 12:26 PM
abqrb2000's Avatar
4th Gear
Definitely flush. I am looking for a wind deflector too. Any suggestions?
Old Feb 8, 2014 | 07:50 PM
unseenone's Avatar
I have the same rattle in the sun roof occasionally. Same symtom, push on it slightly and it will stop. I guess it's time to figure it out, but I'm too lazy. Maybe someone will give us a tip / how to here.
Congrats on the new wheels, you will enjoy it.
Old Feb 8, 2014 | 10:02 PM
spiderman's Avatar
perhaps try a sunroof recalibration. Mine did not close fully one day and the fuse was good. I thought I needed a new motor but found the calibration steps in the owners manual (page 119).
Sun roof calibration:
turn the key to position II (run)
press and hold the front (close) portion of the sunroof switch for 20 seconds. Continue to hold the switch until the sunroof makes one complete cycle (it will open and close, do not release the switch until the sunroof is fully closed and stops moving).
The calibration cannot be performed if the battery voltage is low.
other solutions may include;
replacement of weather seal
adjustment or replacement of tracks, gears, motors etc. if the sunroof fails to close completely
thorough cleaning and lubrication of moving parts and tracks etc.
I have fashioned a home made set of roof rack bars, I am sure that they add wind noise, but that is nothing that the "volume" **** cant fix.
nh9095
Jan 14, 2019 12:36 AM
dig4dave
May 21, 2010 10:04 PM
Saridea
Dec 26, 2006 12:25 PM
east302
Mar 6, 2006 10:28 AM
Randall in NC
Dec 22, 2005 11:59 PM
