New Member with an LR3 Hands Free Microphone Problem
Old Mar 23, 2013 | 04:34 PM
casmor's Avatar
Default New Member with an LR3 Hands Free Microphone Problem
Hello,
I'm a new member from Ontario, Canada looking for advice. I have an LR3 and I'm having a hard time trying to figure out how to fix my problem with the hands free phone system. I am able to make calls through voice command, key pad on the dash, and voice button on steering wheel. Call always connects. I can hear the person on the other end but they can't hear me. Is there something I can do to fix this problem or do I need to have a professional make the repair? Please help.
Old Apr 3, 2013 | 09:26 AM
roverguy7's Avatar
It could be an issue with the microphone, Bluetooth module, Amplifier, or the Nav ECU, if fitted. Since you said you can make a call through voice command, I'm guessing the Mic is ok. Most common issue is with phone comparability with the bluetooth module. Try another phone if you can. If another phone works, and your bluetooth is factory fit, not the accesory module, you can have the software updated, which may or may not help.
Old Apr 5, 2013 | 09:14 PM
bbyer's Avatar
Default Yes, try a second phone.
It may be that all is fine with the BlueTooth in the 3. The problem may be a setting on your phone.
I have a Blackberry 9630 on Telus and these are some of the settings. I seem to recall that until I got them all set correctly, I had lots of problems being head, echo, no connect; could not hear the other side; they could not hear me; it went on and on.
Discoverable: Yes
Allow outgoing calls: Always
Connect on Power UP: Yes
Trusted should show as Yes.
Encryption should be set to Disabled.
Echo Control as Automatic
Old Apr 6, 2013 | 04:19 PM
Rovin4life's Avatar
turn the volume on the phone section of the radio. you adjust it with the **** when you are on a call.
Old May 10, 2019 | 09:37 AM
sly3131's Avatar
Did you figure this out? I just got a 2008 LR3 and connect my iphone and make calls, but no one can hear me when I talk.
gettingerb
Aug 19, 2015 09:51 AM
gettingerb
Audio/Visual Electronics
Aug 17, 2015 11:11 AM
jmhoneybird
LR4
Feb 3, 2011 12:48 AM
MJ2
Jul 27, 2009 10:02 PM
