No crank / no start...
Old Nov 23, 2025 | 04:51 AM
sat159p1's Avatar
4th Gear
Unhappy No crank / no start...
Hey. I have problem with Discovery 3. It drove allright since yesterday. Was repairing sunroof leakage and found out also that sunroof fuse was blown (i havent used it for a while), so I put new fuse in. Since that time I can't start the car. It just does nothing when I turn key to the last position. It's manual transmission model, no no "P" gear lock error possible.
- tested both keys
- No blinking immo icon on the dash
- swapped the starter (SM) relay - no effect.
- all fuses ok
- new battery
I bielieve there's no voltage on below SM terminals when key is in the start position...
Any ideas?
Aleternator and starter are good btw
Old Nov 25, 2025 | 07:06 PM
cybercop's Avatar
When you turn on the car try to crank it, do your door locks actuate and does your flashers come on?
Old Nov 27, 2025 | 02:15 AM
sat159p1's Avatar
4th Gear
No, they don't. Just hear a click somehwere in the passenger foot area.
Old Nov 27, 2025 | 09:04 AM
cybercop's Avatar
Maybe one of your relays on the CJB? After cooking let me look up which one it could possibly be.
BTW, Happy Turkey Day
Old Nov 27, 2025 | 12:04 PM
sat159p1's Avatar
4th Gear
I replaced the relay (should be in the place of the wire looking at pic from1st post) with another one for the headlights (it's identical). No change. I believe there;s no voltage on the (1) temrinal when key is turned to crank. All fuses okay... I\m really confused
Old Nov 28, 2025 | 09:39 AM
cybercop's Avatar
When all fuses check ok, can I assume you checked all the fuses in the interior CJB behind the glove box. Specifically 25&60 (ECM) and 28 (Fuse box Engine ignition)?
Old Dec 3, 2025 | 05:57 AM
sat159p1's Avatar
4th Gear
I will try to check them in the next days. is the "CJB" the fuse box with few small relays under glove box?
Old Dec 3, 2025 | 08:15 AM
cybercop's Avatar
Correct.
Old Apr 19, 2026 | 09:08 PM
hucklebucklr3's Avatar
5th Gear
Was this ever resolved? Have a similar situation
Old May 3, 2026 | 06:45 PM
cybercop's Avatar
Never heard back. The OP had a manual, not a automatic. Do you have a automatic?
