no power
Old Nov 14, 2019 | 08:42 PM
tony1's Avatar
6th Gear
Default no power
2008 lr3 hse
would anyone have any idea why i have no power to my heater switches.my radio on top and the cigerette lighter below have power
i checked the fuses and changed the relay in the fuse box
is there something else i could check
(just joined the site)
Old Nov 15, 2019 | 11:25 AM
LR Techniker's Avatar
Which fuses did you check? I think the fuse for the Climate Control Panel is #51 (10A) behind the glove box.
Old Nov 16, 2019 | 04:11 PM
tony1's Avatar
6th Gear
yes i checked number 51
i also removed the climate control panel to check for power and the power is going to the conection behind the unit
it looks like i need a new switch panel, it dosent even light up when the head lights are on
i wonder if i get a new unit is it a straight swap or does it need to be programed
thank for getting back
Old Nov 17, 2019 | 02:41 AM
Globetrotter448's Avatar
A lot of these items actually switch an earth, so you may have volts but no earth. Check the grounds to the panel and its connectors.
Old Nov 17, 2019 | 09:48 AM
It is best to have them programmed, as they may contain VIN specific software, however if you get a numbers matching used unit, it should be "plug and play". When the unit in my 2008 went out, I swapped in a used one and it fixed my issue (always blowing hot on passenger side, it wasn't the actuator). I only programmed it because I could.
nickm347
Jun 23, 2022 05:45 PM
SteveTheRover
Mar 19, 2020 04:24 PM
tony1
Nov 14, 2019 07:49 PM
thearmlesswonder
May 2, 2013 10:00 PM
diverdad69
Apr 16, 2010 02:30 PM
