No Trailer Lights
Old May 25, 2024 | 02:57 PM
Columbiar's Avatar
Default No Trailer Lights
Tried hooking up to a trailer for the first time today and discovered I’m getting no power to the trailer lights. Issue is not the trailer. I checked all the fuses I could find (4) and all looks good. I’m getting nothing to the trailer and nothing on the dash. When I first connected the trailer and found nothing I turned the truck off and plugged in the GAP. When I tried starting, it turned over a couple times and then stopped. Got all kinds of codes. Then it started but hesitated and had a check engine light. I cleared the codes which turned off the check engine light but code B1C57-14 (2F) won’t clear. Afterwards, the truck continued with a slight hesitation upon starting for several tries but this has gone away. Battery voltage is good. This has all got to be connected in some way. Any thoughts are appreciated.
tks
Old May 25, 2024 | 03:36 PM
Columbiar's Avatar
My bad. Finally found the problem the the wiring harness the second time around.
drzjoint
Jul 30, 2022 08:12 PM
theblackfalcon
Oct 6, 2021 12:00 PM
Livingintheskies
Apr 9, 2018 11:17 PM
AK Rover
Jan 6, 2009 04:12 PM
bamarover
Apr 25, 2007 05:34 PM
