not starting
Old Apr 25, 2016 | 09:06 PM
wdiamond111's Avatar
Default not starting
I am new and I have a 2003 RR that will not start. the starter and battery are new as is a key that opens the doors , but when turned from 0 to I in the ignition, sets off the alarm. Can anyone help.
Old Apr 26, 2016 | 02:20 PM
houm_wa's Avatar
First things first, Beavers fan or ducks fan?
Old Apr 27, 2016 | 02:30 PM
Beavers
Old Apr 27, 2016 | 03:13 PM
houm_wa's Avatar
Go BEAVS! (Class of '96).
So first of all you are in an LR3 section so our knowledge of the RR is limited. What I'd suggest though is doing a "hard reset" first. Remove both battery cables and connect them for 2 minutes (you can use a jumper cable for instance, pick a color and clip on the alligator teeth to each cable end).
If that doesn't work you may need to have your key re-programmed or perhaps the immobilizer is activated.
Old Apr 28, 2016 | 02:54 PM
DavC's Avatar
Will the key not physically go to position II and start?
Will it turn but nothing happens except for the alarm?
May be unrelated but in the LR3 the alarm sometimes goes off if you have a hood sensor go bad.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
readdiscovery
Jul 7, 2006 05:23 PM
nick
Freelander
Mar 14, 2006 04:41 PM
pants
Oct 19, 2005 12:47 AM
nick
Jul 17, 2005 02:04 PM
