OEM vs Arnott vs Bilstein
As you may have seen, I've been quite busy with, new to me, MY08 recently. Over the 4th of July weekend, I had to replace my radiator, thermostat housing, transmission cooler line, performed the transmission fluid change with pan conversion, and an oil change. This followed up with a late night run to the hardware store to make a brass t for the stupid bleeder valve for the coolant system (still have to do the front brakes and replace the upper control arms).
Long story long, I got a suspension fault on my way home from work the other day and after further inspection, I have a large hold in my front passenger side air spring bag.
Finally onto my question, I have been researching what to replace it with for the past few days and I am no closer to an answer from when I started. So, can someone help me decide which I should go with? Here are the links to what I have been looking at:
Arnott
https://www.arnottindustries.com/par...75_gid723.html
Bilstein
Bilstein, Innovation and High Quality Since 1873
OE
LR3 Front Air Spring And Strut Assembly (Part # RNB501580)
I plan on having MY08 for another 100k+ (currently has 127k) so I want something that will last!
Arnott
Bilstein
OE
I replaced my front airbags last year and went with Arnott. I've been happy with Arnott and have 14K miles on them, many of those miles are from dirt and washboard roads. Arnott uses quick-connect air connectors which was a nice touch.
From my research, Arnott seems to be better than OEM. Also, a shop floorman at a LR dealership recommended them so it's not always the case that more $$ means higher quality.
As for Bilsteins, I heard Arnott actually offered a Bilstein shock with their airbags as an option but had to recall them due to performance issues. When I talked to Arnott, they wouldn't tell me why no longer offered the Bilstein option. And they don't offer rear airbags either...
I have heard a lot of complaints about Arnott, but have used them exclusively.
I've had one issue where the top studs all broke on one side approx 5k miles after install. I could have over torqued them but doubt it as the other side was fine. It was replaced under warranty.
The ride quality feels fine and they function as they should, so I vote Arnott.
Regardless of brand, I would recommend changing both sides
I went with Arnott and changed both fronts.
With that many miles on it, ride quality may suffer if you only replace one. I had an air leak on the right front, at 130,000 miles I went with Arnott as they were on sale, and am very happy with them after a year of daily use.
Of course if money is an issue try one and see if you like the way it rides.
Jeff
Jeff
