Oil Filter Assembly Leak
Old May 28, 2022 | 12:54 PM
spinach_e's Avatar
Default Oil Filter Assembly Leak
Hey Guys,
This is a second post (first is about small steering leak), I bought a 2006 LR3 SE V8 about 2 months ago and have been enjoying the hell out of it. Honestly best vehicle I have ever driven. It definitely came with some issues and I'm slowly knocking out each one. This is about a leak in the Oil Filter Assembly. My local mechanic says that the seals all need to be replaced around the oil filter, adapter and mounting bolt. See attached photo below. I'm having trouble finding the seals online. The manual doesn't have parts numbers for them and though i do see tons of seals on rover parts i'm not sure which ones are which. So I'm basically looking for advice on how to identify the seals by part number and find them online, and also any advice from people that have experienced this already. Maybe I should try to clean the assembly using brake cleaner and see specifically where the oil is leaking from? I assume has been leaking for a long time and the leak is just a slow grind. Any advice would be appreciated.
Old May 28, 2022 | 05:38 PM
DakotaTravler's Avatar
It is likely not those o-rings that are leaking and probably the main housing to block seals. This seal sits were you see the most oil in the pic. Part link for example only, always recommend OEM seals:
https://www.autohausaz.com/pn/18855_...RoC8hYQAvD_BwE
Old May 28, 2022 | 09:18 PM
spinach_e's Avatar
sweet. thanks for the reply. i do have that part on my radar. I'll install that and see how it goes. thank you for the part number, can i ask where you got the number from? How do you find part numbers, especially for thinks like seals?
Old May 28, 2022 | 09:19 PM
I have all the part numbers memorized.
Old Jun 1, 2022 | 06:42 PM
spinach_e's Avatar
how did you go about learning the part numbers? is there a resource that lists them all?
shady milkman
Oct 28, 2017 10:14 PM
Jeff Blake
May 12, 2016 08:22 PM
DiscoRover007
Aug 28, 2011 11:44 AM
roverboy
Feb 5, 2009 06:33 PM
