Oil leak at oil cooler (radiator)
Yesterday, I noticed a few drops of oil under the front bumper, drivers side. I removed the lower left side cover and can see that the leak is coming from the radiator where the oil line is attached to.
Is this a common issue and has the dealer corrected this for you? I would like to hear back from folks before I make an appointment. I am just curious if it is the hose or a seal (and of course cost).
Thanks!
Thanks!
V8 or V6 engine, both similar.
I assume the leaking oil is transmission oil as I assume the cooler referred to is the transmission cooler that is built into the engine cooling radiator.
The upper pipe is the return oil back to the tranny; the lower pipe, the hot oil in from the tranny. Both of these pipes feed into the left hand end tank of the engine cooling radiator. (The same end as the lower big engine coolant hose is attached to.)
The good news for me is that I know nothing of this problem; also I have not heard of others complaining either. It therefore does not sound like a common problem but that is not much help to you. It may be that just tightening the hose clamps will resolve the concern.
A bigger concern is when was the tranny oil changed? Regardless of what LR or ZF sort of infers, the tranny oil should be changed prior to 100,000 miles. To LR, life means until the end of the 4 year warranty period, not your life or the life of the engine.
The link below contains some files related to your ZF 6HP26X tranny.
DISCO3.CO.UK Photo Gallery - ZF 6HP26 Automatic Transmission in LR3
I want to get all the issues done all at once. The unfortunate thing is that the dealer near me is new. I am not sure how well the service their vehicles....we will find out.
Usually its just a loose hose. You could try to just tighten the clamp, or
cut the hose back just past the clamp and refit it with a new clamp.
Also you'll see (under the radiator on the l/s corner) a piece of foam.
This will be soaked with trans fluid. You'll need to remove it and degrease that area. If you don't it will appear that is still leaking for quite some time.
I do not believe hoses and pipes are covered by any extended warranty companies
I believe my front sway bar bushing and links are going, maybe the front control arms. I also found out that I am missing the skid plates....uggg...in search of parts....
bcolins
08-13-2013 06:41 PM
