P0000 Error code
Old Nov 27, 2010 | 09:23 AM
minsane's Avatar
4th Gear
Unhappy P0000 Error code
Hi Guys:
My LR3 has been giving me a check engine light with a P0000 error code that I was able to check and clear with my Scangauge. From the research that I have done this means that there is a "Null Error". The car could not fully read the error or there was miscommunication. Has anyone else had this error? What was the outcome?
Thank you!
Old Nov 27, 2010 | 02:11 PM
Rovin4life's Avatar
miscommunication with your scanguage. The federal govt required a change back in 05 to a different form of obd2 scanner program. You have to have a newer one after that time. Its also possible that one isn't upto snuff on the newer ones.
Old Nov 27, 2010 | 10:10 PM
minsane's Avatar
4th Gear
Default Thank you!!!
Thanks Rovin4life. I do have the new version of the scangauge that came out recently unfortunately it is not up to par. I went to l local parts place and borrowed their reader. It was a P0128 code. From the additional research that I have done I think that I have narrowed it down to the thermostat. They seem to be a big wear item. We are at 105K miles now and many people have had failures at around 50K miles.
pixel
May 13, 2011 07:24 PM
raid13
Jan 19, 2009 09:20 AM
BIG g
Dec 7, 2008 07:02 PM
BIG g
Jan 27, 2008 06:40 PM
navysar
Jul 12, 2007 05:18 PM
